MarkM_63051
Jan 23, 2012Nimbostratus
HTTPS Problem
Hello,
Up until now using the F5 has been fairly straight forward. Adding HTTPS certificate support for incoming IE connections however has got me stumped. I have watched the online webinar and tried many variations to get it working without success.
What I am trying to do is to take a working HTTP connection through the F5 to a pool consisting of a pair of Tomcat servers and convert the virtual server connection from HTTP to HTTPS. Wireshark traces show the F5 and the Tomcat communicating with each other and all of the status balls are green. How do I go about debugging my problem? Where do I look to find out what is not happening?
Regards,
Mark
- nitassEmployeecan you try Redirect Rewrite All under http profile?
- MarkM_63051NimbostratusWhat is your Server Side SSL set to in your VS?
- MarkM_63051Nimbostratuscan you try Redirect Rewrite All under http profile?
Would you please give me an example of using:
- nitassEmployeecan you create custom http profile similar to below and assign it to virtual server?
root@ve1100(Active)(/Common)(tmos) list ltm profile http myhttp ltm profile http myhttp { app-service none redirect-rewrite all }
- MarkM_63051Nimbostratusroot@f5-loadbalancer2(Active)(/Common)(tmos) list ltm profile http myhttp ltm profile http myhttp { app-service none redirect-rewrite all }
- nitassEmployeeto create, can you try this?
root@ve1100(Active)(/Common)(tmos) create ltm profile http myhttp redirect-rewrite all
- MarkM_63051Nimbostratuscan you create custom http profile similar to below and assign it to virtual server?
- nitassEmployeeit is under local traffic > profiles > services > http
- MarkM_63051NimbostratusWahooooo ...
