Scott_27805
Mar 21, 2012HTTPS Passthrough not working
In our current environment we use SSL offloading for our Exchange 2010 Outlook Web Access through our F5. We need to stop this just for the MRSProxy service and not any other traffic to the server. I created the iRule below and applied it to the virtual server. However we are still seeing the requests for this URL come through on port 80 instead of 443 in the IIS logs on the OWA server. Can anyone help and tell me where I went wrong? Thanks.
if { [HTTP::uri] starts_with "/EWS/mrsproxy.svc"}{
SSL::disable clientside
We are seeing GET /EWS/mrsproxy.svc – 80 in the IIS log and we should get GET /EWS/mrsproxy.svc - 443
- Brian_69413
are the pool members only configured for port 80? - Scott_27805
No. They are configured for 80 and 443. I can go directly to any of the pool members by their individual IP addresses and hit the URL on 443 without issue. - hoolio
You would need to disable SSL for the serverside connection and select a pool with member(s) on port 80:when HTTP_REQUEST { if { [HTTP::uri] starts_with "/EWS/mrsproxy.svc"}{ SSL::disable serverside pool http_pool } }
Aaron - Brian_69413
Scott, I am talking about the load balancer pool configuration, are the members set like this: x.x.x.x:80 or x.x.x.x:*? If the LB sends traffic to port 80, the server will not be listening for SSL.
Aaron, I think he has offloading already and wants to disable that for this particular traffic. - Brian_69413
Scott, I am talking about the load balancer pool configuration, are the members set like this: x.x.x.x:80 or x.x.x.x:*? If the LB sends traffic to port 80, the server will not be listening for SSL. - Scott_27805
I though that this would be clientside per the document here https://devcentral.f5.com/wiki/iRul...k_URL.ashx. I don't even have a server side ssl profile defined on this virtual server.
The pool for port 80 is the same as the pool for 443. It should be going to the same pool members. Or does this require a different set of pool memebers entirely?
- Brian_69413
I think if your pool members are defined as x.x.x.x:80 then you would need a new pool for x.x.x.x:443 - Scott_27805
Brian, yes my pool members were only on port 80. Can I just add the same pool members again on port 443 or should I remove them and the add them back with a * for the port? - Scott_27805
I created a new pool for 443. Now when I go to the page just for that URL it just hangs. The new pool is showing as available. The iRule is as followswhen HTTP_REQUEST { if { [HTTP::uri] starts_with "/EWS/mrsproxy.svc"}{ SSL::disable serverside pool webmail_443_pool } } - Brian_69413
you need to disable the client side ssl and set the 443 pool
