mikemich_131967
Jun 10, 2014HTTPS Monitor not working but same monitor for HTTP does
I am running an HTTPS monitor below. When i apply the health check in HTTP it works fine but when I add it to HTTPS Monitor it doesn't work. I have used HTTPS monitors before and I am stuck on why ...
Kevin_Davies_40
Nacreous
Jun 10, 2014Do the following command from your F5. This assumes the pool member is on port 443. If not then add :port to then end of pool_member_ip with the port of the pool member you are testing.
curl -k https://pool_member_ip/monitor/status_check
Do you get something back?
Ellison_Zhang_2
May 11, 2016I got expected string "OK" when I use curl -k. but HTTPS monitor still failed.
