mikemich_131967
Jun 10, 2014HTTPS Monitor not working but same monitor for HTTP does
I am running an HTTPS monitor below. When i apply the health check in HTTP it works fine but when I add it to HTTPS Monitor it doesn't work. I have used HTTPS monitors before and I am stuck on why ...
mikemich_131967
Jun 12, 2014Thanks for the feedback everyone. When I was adding or removing the monitor on the HTTPS monitor to the pool. The pool would never change status. I found out that on this the node was being individually monitored within the pool which is not something we normally do. I should have noticed sooner.
