HTTPS health monitor issue
Hi All,
I am trying to validate the VIP, which is failing in the browser stating that "connection reset",
The server that is mapped to the pool is green via the health check, i can use curl -vk https://<serverip>/state.txt --> it gives the right response,
If i do the same with the vip, i get the following error, curl -vk https://<VIPip>/state.txt --> Below error
> GET /state.txt HTTP/1.1
> Host: xxxxxxxxxxxxxxx
> User-Agent: curl/7.47.1
> Accept: */*
* SSL read: error:00000000:lib(0):func(0):reason(0), errno 104
* Closing connection 0
curl: (56) SSL read: error:00000000:lib(0):func(0):reason(0), errno 104
The server is local to the F5, directly connected,
Please let me know if there are any thoughts on this problem.
- Lidev
Nacreous
Hello sathish,
I've already met this type of SSL errorno 104 when I was using an iRule containing errors with processing on the HTTP responses part.
Regards
- sathish_2826
Hi Lidev,
The Irule used on the vip is a standard rule which is used in 1000's of other vip's with no issues,
Do you see any other problem?
- Lidev
Nacreous
It's hard to say without more details about the virtual server and monitoring configuration.
I'll still test without the iRule to see if you can reproduce the issue ;-)
- sathish_2826
Removing Irule didn't help, anyway, thanks for looking into this :)
Hope you have applied default "serverssl" profile to VIP and automap.. Apply and capture the packet. Hope it will work
- sathish_2826
Hi Samir,
Serverssl is applied, SNAT is not required as server is local to the F5, thank you.
Is it working?
- Rodrigo_Albuque
Cirrocumulus
Are you able to ping the VIP?
- sathish_2826
Yes, i do
- Rodrigo_Albuque
Cirrocumulus
Is this a production environment with real certificate/key attached to client SSL profile or you're just testing it with default Client SSL profile? Do you have a client SSL Profile attached to the VIP? If so, disable "Generic Alert" option and you can follow the steps in this article to decrypt TLS traffic: https://devcentral.f5.com/s/articles/Decrypting-TLS-traffic-on-BIG-IP
- Renato_Abreu
Altostratus
Any findings? Having the same issue.
