TJ_Vreugdenhil
Cirrus
Aug 20, 2010HTTPS 1.1 Custom Monitor using receive string
Hello F5 ADV Community:SOL3224 to create a custom HTTPS monitor for 10.1.0 I switched over to a basic TCP monitor, but we are still seeing the syslog errors reported by voltage. I would like to try to craft a HTTPS monitor to look for a specific string of text, and try to stay away from any type of java connection.
I am running into a issue with a custom HTTPS monitor. A voltage server I have this monitor assigned to, is reporting syslog 'java servlet errors'. I have followed
Custom HTTPS monitor:
defaults from https
send "GET / HTTP/1.1\r\nHost: \r\nConnection: Close\r\n\r\n"
Do you think the following HTTPS monitor looks right, and would meet my needs, or would you suggest something different?
SEND STRING:
send "GET / HTTP/1.1\r\nHost: voltage-ps-0000.xxxxxxxx.com/login Close\r\n\r\n
RECEIVE STRING:
Email Encryption Provided by Voltage SecureMail
Thanks!
-Tj
