gaza_104946's avatar
gaza_104946
Jul 27, 2011
HTTP::path not updating within iRule
Running 10.2 HF2
I originally had a iRule that was rewriting incoming requests
if { [HTTP::path] equals "/abc" } {
log local0. "[virtual name] [IP::client_addr] detected old path /abc and modified to /xyz"
HTTP::path "/xyz"
Which was working fine and the back-end server was seeing /xyz
I then need to LB to different back-ends based on the path and added this extra code
switch -glob [HTTP::path] {
"/abc" { pool pool_abc }
"/xyz" { pool pool_xyz }
What I found is that the correct pool was not being used.
I then moved the 2nd set of code to another iRule which was placed after the original iRule for the VS and it worked!!
Further investigation showed that if you set HTTP::path within an iRule that you don't get the new value, but a following iRule will get the new value.
Is there a way I can get around this as I'd like to simplify the configuration back into a single irule?
Note: that this is not the only code in the iRule or the only iRule, so I really am looking for a code solution rather than using HTTP classes.
  • hoolio's avatar
    hoolio
    Hi Gaza,
    Most HTTP:: commands are cached within the same event and priority. So what you're seeing is expected. If you want to use the modified value of after changing the path with HTTP::path, you can save it to a variable:
          set path "/xyz"
          HTTP::path $path
       switch $path {
    Aaron
  • Thanks Aaron,
    I suppose I just needed that confirmed as I didn't find anything on the site.
    Cheers
