HTTP::disable keep cookie persistence
Hello I'm using a iRule that disable HTTP profile when a particular URI is requested (this URL calls non http traffic using port 80 !!!).
With regular URIs I have persistence with cookie.
Disabling HTTP profile the client will keep previus persistence ?
The idea is that when client request a standard URI it has HTTP profile enabled and cookie persistence and when it request the particular URI i keeps the persistence on the selected node and the traffic bypass the http profile. Anyway if the http profile is bypassed the persistence shall not be lost.
Here the Irule
when CLIENT_ACCEPTED {
HTTP::enable
if { [HTTP::uri] contains "deviantpoint.downloadzip/downloadzip.aspx"} {
HTTP::disable
pool xxx_pool
else {
pool xxx_pool
Anyone has comment or suggestion on that ?
- What_Lies_Bene1
I think the persistence would be maintained for the actual HTTP traffic as long as it's flowing over different TCP connections. The issue is if the same connection within a session is used for the HTTP and non-HTTP traffic. Once the HTTP::disable command is used it will apply for the lifetime of that connection and HTTP::enable won't re-enable it as the CLIENT_ACCEPTED event is only fired once when a connection is first established. Move it to a HTTP event and that won't fire either as HTTP processing has been disabled. Catch 22 really.
However, you might be lucky and find a new connection is established just for the non-HTTP traffic - lets hope so. - nitass
Employee
Anyway if the http profile is bypassed the persistence shall not be lost.it seems persistence is also gone.[root@ve10:Active] config b virtual bar list virtual bar { snat automap destination 172.28.19.252:80 ip protocol 6 rules myrule persist cookie profiles { http {} tcp {} } } [root@ve10:Active] config b pool foo list pool foo { members { 200.200.200.101:80 {} 200.200.200.111:80 {} } } [root@ve10:Active] config b rule myrule list rule myrule { when CLIENT_ACCEPTED { log local0. "client [IP::client_addr]:[TCP::client_port]" } when HTTP_REQUEST { set uri [HTTP::uri] if { $uri contains ".gif" } { HTTP::disable pool foo } else { pool foo } } when SERVER_CONNECTED { log local0. "client [IP::client_addr]:[TCP::client_port] server [IP::server_addr]:[TCP::server_port]" } when HTTP_RESPONSE { log local0. "client [IP::client_addr]:[TCP::client_port] server [IP::server_addr]:[TCP::server_port] uri $uri" } } there were 2 http requests; the 1st one was /index.html (no.1) and the 2nd one was /f5.gif (no.4) with cookie. i assumed it is on different tcp connection, so i created a new tcp connection for 2nd request. the log showd the 2nd request was forwarded to new pool member. [root@ve10:Active] config tail -f /var/log/ltm (1) Apr 23 14:59:42 local/tmm info tmm[4950]: Rule myrule : client 172.28.19.251:50884 (2) Apr 23 14:59:42 local/tmm info tmm[4950]: Rule myrule : client 172.28.19.251:50884 server 200.200.200.101:80 (3) Apr 23 14:59:42 local/tmm info tmm[4950]: Rule myrule : client 172.28.19.251:50884 server 200.200.200.101:80 uri / (4) Apr 23 14:59:51 local/tmm info tmm[4950]: Rule myrule : client 172.28.19.251:50885 (5) Apr 23 14:59:51 local/tmm info tmm[4950]: Rule myrule : client 172.28.19.251:50885 server 200.200.200.111:80
