KaiTT's avatar
KaiTT
Sep 10, 2024
HTTP x-forward-for
Hi all,
I have configured the x-forward-for virtual server as below.
<vitual server>
type : standard
protocol : tcp
Source Address Translation : Automap
HTTP Profile : Added profile with 'Insert X-Forwarded-For' enabled
The symptoms are as follows.
1) Configure the service port of the virtual server to 80 or 8080.
   - BIG-IP recognizes the port as http and adds the Client IP to the header.
2) Configure the service port of the virtual server to 11211.
   - BIG-IP recognizes the port as TCP and does not operate X-forward-for.
I have a few questions.
Q1) For X-forward-for to operate, does the HTTP well-known(80,8080) port that BIG-IP knows must be configured as a service port?
Q2) Is there a way to make X-forward-for work by configuring unknown-port on the service port?
Q3) Are there any other service ports that F5 recognizes with HTTP other than 80,8080?
Thanks,
    • KaiTT's avatar
      KaiTT
      The capture below is the result of configuring XXF with 11211 ports.
      Because BIG-IP recognizes 11211 port as TCP, it appears that HTTP headers cannot be added.
  • I hope you have applied correct profiles. Could you please check F5 able to communicate with backend pool or not. Please take a full capture that include front and backend communication. If backend communication success only , F5 will start the http connection.
    Hope your vip is up and F5 able to connect server via automap. Try via capture
