SSHSSH_97332
Aug 08, 2014HTTP URI Parts
http://www.example.com:8080/main/abc/index.jsp?user=test&login=check
In the above , if i want to print second part of URI , which is here "abc" , is this [ [HTTP::uri] 2] or What ?
nitass
Employee
Aug 10, 2014Yann is absolutely right.
config
[root@B6900-R69-S40:Active:Standalone] config tmsh list ltm rule qux
ltm rule qux {
when RULE_INIT {
for { set i 1 } { $i < 10 } { incr i } {
log local0. "\[getfield /main/abc/index.jsp?user=test&login=check / $i\] = [getfield /main/abc/index.jsp?user=test&login=check / $i]"
/var/log/ltm
[root@B6900-R69-S40:Active:Standalone] config tail -f /var/log/ltm
Aug 10 06:47:01 B6900-R69-S40 info tmm[15765]: Rule /Common/qux : [getfield /main/abc/index.jsp?user=test&login=check / 1] =
Aug 10 06:47:01 B6900-R69-S40 info tmm[15765]: Rule /Common/qux : [getfield /main/abc/index.jsp?user=test&login=check / 2] = main
Aug 10 06:47:01 B6900-R69-S40 info tmm[15765]: Rule /Common/qux : [getfield /main/abc/index.jsp?user=test&login=check / 3] = abc
Aug 10 06:47:01 B6900-R69-S40 info tmm[15765]: Rule /Common/qux : [getfield /main/abc/index.jsp?user=test&login=check / 4] = index.jsp?user=test&login=check
Aug 10 06:47:01 B6900-R69-S40 info tmm[15765]: Rule /Common/qux : [getfield /main/abc/index.jsp?user=test&login=check / 5] =
Aug 10 06:47:01 B6900-R69-S40 info tmm[15765]: Rule /Common/qux : [getfield /main/abc/index.jsp?user=test&login=check / 6] =
Aug 10 06:47:01 B6900-R69-S40 info tmm[15765]: Rule /Common/qux : [getfield /main/abc/index.jsp?user=test&login=check / 7] =
Aug 10 06:47:01 B6900-R69-S40 info tmm[15765]: Rule /Common/qux : [getfield /main/abc/index.jsp?user=test&login=check / 8] =
Aug 10 06:47:01 B6900-R69-S40 info tmm[15765]: Rule /Common/qux : [getfield /main/abc/index.jsp?user=test&login=check / 9] =
