Julio_Vivero_48's avatar
Julio_Vivero_48
Mar 23, 2006
HTTP Payload replace - charset problem
Hi everyone,
I'm trying to use the HTTP payload replace irule that is available at this forum but i'm facing the following problem:
The web where i'm trying to use this irule is encoded with iso-8859-1 charset, but for some reason it seems that the i-rule changes the encoding of the http payload to utf-8, and hence the client browser does not display correctly some characters like accents, etc.
I've tried to use the encoding command from tcl to force a conversion to iso-8859-1 but (though there is not error message when I introduce it at the LTMs administration web) I get the following error message at the ltm log, when the irule is executed:
"TCL error: Rule response_change_https - invalid command name "encoding" while executing "encoding convertto iso-8859-1 $new_response"
Any idea would be of great help.
Thanks in advance.
Best regards,
Julio
  • Hi,
    I have the same problem as you , and it does not seem to be a specific problem (forum question 9062 for instance).
    I have created a case with F5 support, I will tell tou the answer in the next few days(if I get one).
  • Colin_Walker_12's avatar
    Colin_Walker_12
    Historic F5 Account
    Have you tried using the stream profile instead of the iRule?
    The stream profile is a relatively new feature that provides the payload replacement functionality out of the box. It's also a bit more robust, faster, etc.
    I'd be interested to hear if you had the same issue.
    Thanks,
    Colin
  • Deb_Allen_18's avatar
    Deb_Allen_18
    Historic F5 Account
    Don't forget that if you use the stream profile with different length source and target values, and your servers are sending data unchunked, you'll need to enable re-chunking on the HTTP profile, otherwise the Content-Length header will still contain the original (now incorrect) content length value (headers are sent before the stream replacement is performed)
    /deb
  • I have found similar problem. I am reading packet content with TCP::payload and then writing it to another packet using TCP::payload replace. The packet contains binary data (including a lot of zeros). After rewriting it is different and longer than original. In particular, it seems that byte 00 is changed to two bytes: C080. It damages my data. What can I do about it? Did the support solve this?
    I found another threads on this forum, referencing similar problems
    http://devcentral.f5.com/Default.aspx?tabid=53&view=topic&forumid=5&postid=9062
    http://devcentral.f5.com/Default.aspx?tabid=53&view=topic&forumid=5&postid=3093
    Deb_Allen_18
    Historic F5 Account
    I've dug up a number of other posts on the same topic as well. Please post back with the version(s) you've tested on, and I'll escalate a consolidated case to Support.
    /deb
  • I am using BIG-IP 9.4.0 and I have already reported a support case regarding the problem with TCP::payload replace. The case number is C371366. I am waiting for solution now.
    Deb_Allen_18
    Historic F5 Account
    OK, great.
    Looks like you've discovered a product defect, and the case is progressing well, so I'll wait for resolution as well before escalating anything further.
    /deb
  • Raymond_Feng_97's avatar
    Raymond_Feng_97
    Historic F5 Account
    CR47762 created-- but the RFE seems not to be accept, workaround is to use
    binary format c* {1 2 3 0 }
    instead of "\0x01\0x02\0x03\0x00"
