Peak10_RAL_Engi's avatar
Peak10_RAL_Engi
May 21, 2010
http path match not working
I have an existing irule that matches incoming http requests to various path text strings and if there is a match, it sends those requests to a different pool then the default pool configured on that virtual server. I've added some new redirects that need to match, and so far they are not matching on my tests. I was hoping that someone could help me troubleshoot why the example below is not matching:
Current irule:
switch -glob [string tolower [HTTP::path]] {
"*.asp" -
"*.aspx" -
pool pool_B
log local0. "pool_B chosen."
default {
pool pool_A
log local0. "pool_A."
I want to add the following text match to redirect to pool_B:
"/?abc=de"
When I add it as follows:
"*.asp" -
"*.aspx" -
pool pool_B
default {
pool pool_A
  • Your going to have to change to [HTTP::uri]
    Example: http://www.website.com/subcontent?abc=de
    [HTTP::host] = www.website.com
    [HTTP::path] = /subcontent
    [HTTP::uri] = /subcontent?abc=de
    Path - http://devcentral.f5.com/wiki/default.aspx/iRules/http__path.html
    URI - http://devcentral.f5.com/Wiki/default.aspx/iRules/http__uri.html
    or
    You could do an [HTTP::query] compare.
    Query - http://devcentral.f5.com/wiki/default.aspx/iRules/http__query
