HTTP monitor issue
I have a VE machine, BigIP BIG-IP 11.2.1 Build 807.0 Hotfix HF1
When trying to create a custom HTTP Monitor with custom headers (as seen in https://support.f5.com/kb/en-us/solutions/public/2000/100/sol2167.html)
the monitor then returns Error 400 Bad Request, when tracing we see that the headers arrive twice in the same request.
- What_Lies_Bene1
Can you post your monitor configuration please (minus sensitive data)?
- Andrey23_135672
I can post TCP Stream
GET /api/charm/monitor HTTP/1.1 Host: myhost.com User-Agent: Mozilla/5.0 (Windows NT 6.1; WOW64; rv:23.0) Gecko/20100101 Firefox/23.0 Accept: text/html,application/xhtml+xml,application/xml;q=0.9,/;q=0.8 Accept-Language: en-US,en;q=0.5 Accept-Encoding: gzip, deflate Connection: keep-alive
HTTP/1.1 400 Bad Request Content-Type: text/html; charset=us-ascii Server: Microsoft-HTTPAPI/2.0 Date: Sun, 13 Oct 2013 13:37:49 GMT Connection: close Content-Length: 339
host.com"> Bad Request
Bad Request - Invalid HeaderHTTP Error 400. The request has an invalid header name.
- nitass
Employee
this is mine.
[root@VIP4400-R69-S33:/S2-green-P:Active:Standalone] config tmsh list ltm monitor http myhttp ltm monitor http myhttp { defaults-from http destination *:* interval 5 send "GET /api/charm/monitor HTTP/1.1\\r\\nHost: myhost.com\\r\\nUser-Agent: Mozilla/5.0 (Windows NT 6.1; WOW64; rv:23.0) Gecko/20100101 Firefox/23.0\\r\\nAccept: text/html,application/xhtml+xml,application/xml;q=0.9,/;q=0.8\\r\\nAccept-Language: en-US,en;q=0.5\\r\\nAccept-Encoding: gzip, deflate\\r\\nConnection: keep-alive\\r\\n\\r\\n" time-until-up 0 timeout 16 } [root@VIP4400-R69-S33:/S2-green-P:Active:Standalone] config ssldump -Aed -nni 0.0 port 80 New TCP connection 1: 200.200.200.33(41254) <-> 200.200.200.101(80) 1381792390.8140 (0.0013) C>S --------------------------------------------------------------- GET /api/charm/monitor HTTP/1.1 Host: myhost.com User-Agent: Mozilla/5.0 (Windows NT 6.1; WOW64; rv:23.0) Gecko/20100101 Firefox/23.0 Accept: text/html,application/xhtml+xml,application/xml;q=0.9,/;q=0.8 Accept-Language: en-US,en;q=0.5 Accept-Encoding: gzip, deflate Connection: keep-alive --------------------------------------------------------------- 1381792390.8156 (0.0015) S>C --------------------------------------------------------------- HTTP/1.1 404 Not Found Date: Tue, 15 Oct 2013 13:03:00 GMT Server: Apache/2.2.3 (CentOS) Content-Length: 290 Connection: close Content-Type: text/html; charset=iso-8859-1 404 Not Found Not Found The requested URL /api/charm/monitor was not found on this server. Apache/2.2.3 (CentOS) Server at myhost.com Port 80 --------------------------------------------------------------- - Kevin_Stewart
Employee
It may be worthwhile to troubleshoot this from cURL on the command line. Use the -v option for extra verbosity, and use the -H option to add additional headers. Example:
curl -v http://10.10.10.10/api/charm/monitor -H "Host: myhost.com" -H "User-Agent: Mozilla/5.0 (Windows NT 6.1; WOW64; rv:23.0) Gecko/20100101 Firefox/23.0" -H "Accept: text/html,application/xhtml+xml,application/xml;q=0.9,/;q=0.8" -H "Accept-Language: en-US,en;q=0.5" -H "Accept-Encoding: gzip, deflate" -H "Connection: keep-alive"
