prasadpkulkarni's avatar
prasadpkulkarni
Apr 20, 2011
HTTP health monitor using iRule
Hi
Need help to configure Health Monitor using iRule
- We have two web Servers in Active / Standby mode , running three websites on each server (on three seperate IP with IP Bindings) , our requirement is if any one of the website in a Pool goes down , all web sites should be shifted to other Pool.
Issue with normal HTTP health monitor is that it deosn't detect the health monitor ( ASP page) configured for other website ( It should be because it deosn't find path for the Virtual directory) , so the health monitor marks the site as down even if it is up. Is there any way to make it work with help of iRule or any ?? please refer me to the solution if already provide ( I am new to this group)
Thanks & regards
  • Hi Prasad,
    An iRule cannot do monitoring activities. If you have setup monitors much like Aaron (Aka Hoolio) had stated then perhaps the next step is to log into the LTM at the shell level and run a couple of commands
    You can use the telnet command to connect to the pool member and test each server IP address with the site URL that you are using as a monitor. For example:
    telnet
    Next, at the prompt enter an appropriate HTTP request line and HTTP headers, hitting Enter once after each line. For example:
    GET /abc.asp HTTP/1.1
    Host: abc.com
    Connection: close
    GET /123.asp HTTP/1.1
    Host: 123.com
    Connection: close
    GET /xyz.asp HTTP/1.1
    Host: xyz.com
    Connection: close
    This should simulate what each monitor should see as it polls the website.
    I hope this helps
    Bhattman
  • Thank you all for your valuable suggestions on my requirement !!
    Finally I could achieve this with little different approach with the help of F5 supports of course !!
    I split the pool into active & standby nodes and then I configured iRule to detect active members in the pool with the help of health monitor for individual pool.
    below is the iRule for this config.
    VS1->pool1->site1-active
    VS2->pool2->site2-active
    VS3->pool3->site3-active
    pool4->site1-standby
    pool5->site2-standby
    pool6->site3-standby
    For irule, there are three irules and should be applied to VS configuration seperately.
    1) iRule1-->VS1:
    if { ([active_members pool1] < 1) or ([active_members pool2] < 1) or ([active_members pool3] < 1) } {
    pool pool4
    pool pool1
    2) iRule2->VS2:
    pool pool5
    pool pool2
    3) iRule3->VS3:
    pool pool6
    pool pool3
  • I am trying the opposite here. I have two web servers with 10 websites (using header for all 10 websites) equally load balanced behind F5. If one of the website goes offline i would like traffic for other 9 websites to continue to loadbalance and the traffic directed to the website that is down should go to other pool member without marking the whole server offline. I want my monitors to look at the header requests and load balance. Thanks..
  • hoolio's avatar
    hoolio
    Hi OZ,
    You can specify a host header in the HTTP/S monitor send string:
    GET /file.html HTTP/1.1\r\nHost: myhost.example.com\r\nConnection: Close\r\n\r\n
    So you can create a pool and monitor per web site. If you associate a monitor with the pool (not a node) and that pool member gets marked down, it will not affect the same IP:port configured as a member in a different pool.
    Aaron
