HTTP Class to iRule Migration for 11.4.0 or later.
Hello Folks,
I am working on a migration project for one of the customers who is running 11.2.1 HF8 currently and upgrading to 11.6.0.
I have converted most of the HTTP Classes/iRule for 11.6.0 however there is one iRule is causing trouble.
Current HTTP Class looks as following.
paths {
/geoportal(/.*)\?
/arcgis(/.*)\?
/directories(/.*)\?
/mapviewer(/.*)\?
/mapviewerar(/.*)\?
/mapviewerbeta(/.*)\?
/geoportalbeta(/.*)\?
/proxy(/.*)\?
/arcgis_js_api(/.*)\?
/ogc(/.*)\?
/tokenservice(/.*)\?
/rest(/.*)\?
/OntologyService(/.*)\?
/services(/.*)\? }
pool /Common/SDI_Pool_8085
Since the HTTP Path needs to be defined which matches the regex, I couldn't make further progress. Can anyone help me to configure an iRule to achieve the above?
Any help will be highly appreciated.
Thanks, Darshan
- swo0sh_gt_13163
Altostratus
Hello Folks,
I was trying to configure an iRule to match above. I have end up with the following. Can anyone confirm if this would work as a replica of above?
when HTTP_REQUEST { switch -regexp [HTTP::path] { "/geoportal(/.*)\?" "/arcgis(/.*)\?" "/directories(/.*)\?" "/mapviewer(/.*)\?" "/mapviewerar(/.*)\?" "/mapviewerbeta(/.*)\?" "/geoportalbeta(/.*)\?" "/proxy(/.*)\?" "/arcgis_js_api(/.*)\?" "/ogc(/.*)\?" "/tokenservice(/.*)\?" "/rest(/.*)\?" "/OntologyService(/.*)\?" "/services(/.*)\?" } pool Test_Pool }Above iRule doesn't show any syntax errors, however if someone can confirm if this would serve the purpose or not, would be a great help.
Thanks folks!
