HSTS - Header not inserted with iRule
Following is my iRule which is attached to $mydomain$ (http) VirtualServer in F5 for HSTS, but it is not inserting the "Strict-Transport-Security" header in the http response. When I run "curl -s -D- $mydomain$.com.au | grep Strict", it doesn't return anything. Am I missing something here? Please advise...
when HTTP_REQUEST { HTTP::respond 301 Location "https://[HTTP::host][HTTP::uri]" }
when HTTP_RESPONSE { HTTP::header insert Strict-Transport-Security "max-age=31536000" }
Thanks and regards.
Rana
- R_Eastman_13667Historic F5 Account
Try this in your HTTP_RESPONSE event and then check the /var/log/ltm log.
foreach headerName [HTTP::header names] { append headerNames " |$headerName: [HTTP::header value $headerName]" } log local0. "$headerNames" - Brad_Parker
Cirrus
Are you attaching the HSTS response iRule to your HTTPS VIP? The HSTS header should only be sent via HTTPS.
- Virtualrana_132
Hi Guys... Thank you for your responses.
@ Eastman: I've added the bit you mentioned and following is how the iRule looks like. Still no luck and the log shows nothing.
iRule for HSTS HTTP Virtualswhen HTTP_REQUEST { HTTP::respond 301 Location "https://[HTTP::host][HTTP::uri]" }
@ bepsoccer: My understanding: I applied the iRule to http VS as the first line of the iRule is HTTP REDIRECT, so i didn't apply the iRule to HTTPS VS. Please correct me if I am wrong.
Thanks guys, appreciate your help.
Rana
Hello,
As your http VS directly answer with a redirect, your HTTP_RESPONSE event is never triggered.
You should build your own irule in an HTTP_REQUEST event and use the following command instead :
HTTP::respond 302 noserver Location "https://www.domain.org" Strict-Transport-Security "max-age=31536000"
BR
Yann
- Brad_Parker
Cirrus
Your Virtual server that is listening for HTTP should have one iRule :
when HTTP_REQUEST { set my_loc "https://[HTTP::host][HTTP::uri]" TCP::respond "HTTP/1.1 301 Moved Permanently\r\nLocation: $my_loc\r\nConnection: close\r\nContent-Length: 0\r\n\r\n" TCP::close }Your virtual server that is handing HTTPS has to have a client SSL profile and use a different iRule:
when HTTP_RESPONSE { HTTP::header insert "Strict-Transport-Security" "max-age=15552000; includeSubDomains" }If you are going to use HSTS your HTTP response should be 301 not 302. Also, the specification states that the HSTS header should only be sent by the HTTPS site.
- Virtualrana_132
Hi Guys,
It was my lack of understanding about how the iRules were triggering.
Both Yann and bepsoccer are correct, that HTTP_RESPONSE event was never triggered and needed to have the Separate iRule attached to https VS with the following .
when HTTP_RESPONSE { HTTP::header insert Strict-Transport-Security "max-age=15552000; includeSubDomains" }
Really appreciate your help guys.
Thank you
Rana
- Colin_Stubbs
Altostratus
This can also be caused by Web Acceleration or manual use of iRule CACHE commands.
e.g. HTTP_RESPONSE will not fire on anything pulled from cache.
You can use CACHE_RESPONSE instead. I now use two rules and attach as appropriate.
when HTTP_RESPONSE { HTTP::header replace Strict-Transport-Security "max-age=31536000; includeSubDomains" }And,
when CACHE_RESPONSE { CACHE::header replace Strict-Transport-Security "max-age=31536000; includeSubDomains" } - Simon_Waters_13
Recent versions have HSTS on the HTTP profile. - Justin_Zhang_24
hey guys, may i know what is the difference between the following 2 lines?
HTTP::header insert Strict-Transport-Security "max-age=31536000; includeSubDomains"
