lizhuh_55036's avatar
lizhuh_55036
May 29, 2009
How to use pyControl to retrieve Failover.UnitId?
I am trying to use pyControl to retrieve Failover.UnitId,
db = pyControl.BIGIP(
hostname = host,
username = username,
password = password,
wsdl_files = ['Management.DBVariable']
unitid = db.Management_DBVariable.query(['Failover.UnitId'])['return']
But it crashed with following error msg
File "C:\view\LB\vcc\sw\java-modules\da\lb\bigip\src\inventory.py", line 64, in get_failover
File "C:\Python25\lib\site-packages\zsi-2.1_a1-py2.5.egg\ZSI\ServiceProxy.py", line 324, in __call__
File "C:\Python25\lib\site-packages\zsi-2.1_a1-py2.5.egg\ZSI\ServiceProxy.py", line 204, in call_closure
TypeError: Not supporting SOAPENC:Arrays or XSD:List
According to the published soap API,
VariableNameValue [] query(
in String [] variables
My syntax was correct. Could someone share what I did wrong here?
Linda
  • Hi Linda: looking at the iControl SDK it looks like you need to pass a keyword argument to this method. Here's the correct syntax:
     In [4]:  b.Management_DBVariable.query(variables = ['Failover.UnitID'])
     Out[4]: {'return': [{'name': 'Failover.UnitID', 'value': '1'}]}
    Also, when in question, you can print a hidden variable for any method, '_h', which will give you a hint as to parameters:
     In [6]: print b.Management_DBVariable.query._h
     InParams Count: 1
     variables:              Common.StringSequence
     OutParams Count: 1
     return:         Management.DBVariable.VariableNameValueSequence
    I hope this helps,
    -Matt
