MOHIT_125417
Altostratus
Dec 21, 2014How to use openssl Command in F5 LTM Box
Hi Experts,
Please let me know with example.
- Michael_Jenkins
You could start with this link: Introducting OpenSSL for the BIG-IP
To connect to the device, you'll need an SSH client like PUTTY.
- Jose_MartinezA
While you are on CLI use the following syntax as an example:
openssl s_client -connect WEB_SERVER_IP_ADDRESS:443
The certificate should display and you should be able to run commands, in my case I did a test to a web server and used the following command
GET / HTTP/1.1 Connection: close
Then hit enter 2 times
Hope this helps you.
