Nyam_220167
Nov 27, 2018How to restore ltm with bigip.conf and bigip_base.conf file
Hello, I don't have UCS file and I'm trying to rebuild the ltm using bigip.conf and bigip_base.conf file. I have merged these 2 files with the backup and have tried to load the configuration but it is not loading the configuration. And I have lost the access to management IP.
Can anyone suggest how to restore using the ltm using this 2 files?
- stan_piron
Cumulonimbus
You can try to import both files with commands
tmsh load sys config merge file /tmp/bigip_base.conf tmsh load sys config merge file /tmp/bigip.confMerge parameter is mandatory to import the file without erasing existing configuration
