How to replace Citrix Secure Gateway with F5 LTM?
Our company has a growing number of CSG's which we currently just L4 pass-thru SSL traffic to. Ideally, we would like to redesign this to replace our CSG tier completely with our LTM. I've been getting mixed feedback on some customers doing this successfully and wanted to see if there was any official recent deployment documentation on this? Thx!
This deployment guide should help: http://www.f5.com/pdf/deployment-guides/citrix-vdi-iapp-v1_1-dg.pdf
- Greg_Crosby_319Historic F5 Account
Here is the most recent DG which walks through intergrating APM+LTM with citrix. One of the easiest way to configure your BIG-IP is to download and deploy using the noted iApp. I would also check out the latest APM support Matrix documentation on ask f5 to determine which tmos version you should be running on to support your specific server and client versions.
- Matt_Dierick
Employee
The right link for the APM support client matrix : http://support.f5.com/kb/en-us/products/big-ip_apm/manuals/product/apm-clientcompatmatrix-11-4-1.html?sr=36854401
Like Greg and Michael, I advice you to read the Deployment Guide in order to understand how to use LTM and APM with Citrix. APM is needed is order to support the reverse proxy mode in ICA file.
