caulfiedd_spurr
Cirrus
May 26, 2020how to read the output of show pool a p detail on GTM
here is the output of show pool detail comment .
I have few questions:
- what does prefer 100 mean in the output .
- what does global pick 100 mean in the output.
show pool a p-sample.com detail
Gtm::Pool::A p-sample.com
Status
Availability : available
State : enabled
Reason : Available
Load Balancing
Preferred 104
Alternate 0
Fallback 0
Returned from DNS 0
Returned to DNS 0
Dropped 0
| Gtm::Pool Member: p-sample.com:A vs-DC1_samples-443:server1
| Status
| State : enabled
| Reason : Available
| Load Balancing
| Preferred 100
| Alternate 0
| Fallback 0
| Gtm::Virtual Server: vs-DC1_samples-443
| Status
| Availability : unknown
| State : enabled
| Reason :
| Destination : 192.16.1.2:443
| Link Name ---
| Global
| Picks 100
| Connections 0
| Virtual Server Score 0
| Throughput In Out
| Bits/sec 0 0
| Packets/sec 0 0
| Gtm::Pool Member: p-sample.com:A vs-DC2_samples-443:server2
| Status
| State : enabled
| Reason : Available
| Load Balancing
| Preferred 101
| Alternate 0
| Fallback 0
| Gtm::Virtual Server: vs-DC2_samples-443
| Status
| State : enabled
| Reason :
| Destination : 172.16.1.3:443
| Link Name ---
| Global
| Picks 101
| Connections 0
| Throughput In Out
| Bits/sec 0 0
| Packets/sec 0 0
- Grumpy_Cat
Cirrus
'Preferred' is referring to the preferred load balancing method used in the pool which the bigip tries first and the value (100) is how many times this method has been selected. Global 'Picks' value (100) is how many times that pool member has been selected.
Kind regards
Ben
