  • Do you want to execute dig on the target BIG-IP remotely to (perhaps) test the DNS resolver on the box? If so, executing ping via POST /mgmt/tm/util/ping would do. Pinging to a remote device with its domain name would resolve its IP address. For example, ping'ing to www.google.com from my test BiG-IP;
    curl -sku admin:admin https://<BIGIP>/mgmt/tm/util/ping \
      -X POST -H "Content-Type: application/json" \
     -d '{"command":"run", "utilCmdArgs": "-c 3 www.google.com"} ' | \
     jq -r .commandResult
    PING www.google.com (172.217.14.228) 56(84) bytes of data.
    64 bytes from 172.217.14.228 (172.217.14.228): icmp_seq=1 ttl=128 time=198 ms
    64 bytes from 172.217.14.228 (172.217.14.228): icmp_seq=2 ttl=128 time=198 ms
    64 bytes from 172.217.14.228 (172.217.14.228): icmp_seq=3 ttl=128 time=199 ms
    --- www.google.com ping statistics ---
    3 packets transmitted, 3 received, 0% packet loss, time 1999ms
    rtt min/avg/max/mdev = 198.649/198.974/199.350/0.288 ms
  • P.S. Do not forget the "-c 3" ping command option. Otherwise, the ping runs forever, which results in REST call timeout. See man ping.
  • Ah, we do have /mgmt/tm/util/dig endpoint.
    curl -sku admin:admin https://$HOST/mgmt/tm/util/dig \
      -X POST -H "Content-type: application/json" \
      -d '{"command":"run", "utilCmdArgs":"www.google.com"}'  | \
    ; <<>> DiG 9.11.8 <<>> www.google.com
    ;; global options: +cmd
    ;; Got answer:
    ;; ANSWER SECTION:
    www.google.com.         93      IN      A       216.58.193.68
