Thanadon_Wattan
Feb 15, 2005how to parse each element in "data group list"
when I use [llength $::data_group_name], an error occurs like this :
- list element in braces followed by "" instead of space while executing "llength $::CRP_Mapping"
anyone have any idea, what wrong with my syntax?
or have another syntax/function to get element in datagroup. Please help!!
my data group is 'string' type. thank you.
- bl0ndie_127134Historic F5 AccountI think you may be having problems with the underscores. Try putting the name inside braces like this ...
{::data_group_name} - hoolio
The change you make to a datagroup should be made to the config running in memory, but will not be saved (even by manually running 'b save' to write the config from memory to file).
Here is an example iRule which shows an element being appended to the list:when RULE_INIT { log local0. "\$::test_class: $::test_class (length: [llength $::test_class])" lappend ::test_class a_new_element log local0. "\$::test_class: $::test_class (length: [llength $::test_class])" }
Log output:
Rule : $::test_class: item10 item4 item2 item1 (length: 4)
Rule : $::test_class: item10 item4 item2 item1 a_new_element (length: 5)
Can you post the actual rule you're testing as well as the logs showing the issue?
Aaron
