Gouri's avatar
Gouri
Mar 18, 2019
How to modify HTTP URI using ILX Plugin (v13+)
I am trying to implement ILX Plugin for modifying certain HTTP parameters before forwarding the request to the server. I am able to modify the headers using setHeaders. However, I am unable to find a method to modify the URI.
eg.
/a/b/c?p=np (Transform to) /catch-all?p=np
Is there a method I can use to modify the URI ?
  • It may be simpler to just pass the data back to the initial iRule then change the URI from there.
