How to know how much performance left on F5
Hi everyone,
Just like subject. Did we have a Tool to test how much performance left on F5?
example.If we currently have 5000 active connection and Throughput 150Mbps and TPS 0.2 tps (Don't know why it is 0.2 not some integer. want to know too:) )
Can I use tool to know how many Active con and TP left for future application?
Or I just need to compare with BIG-IP platform datasheet?
If I have no choice but to compare with datasheet,
Is Active connection on Performance graph the same as L4 connection per sec on datasheet? and
Is HTTP request on Performance graph the same as L7 request per sec on datasheet?
Then what is L4 HTTP request per sec value on performance graph? and
- why SSL TPS is not integer value?
Sorry for my bad grammar and many question at once.
Thank you
- Mahmoud_Eldeeb_
dashboard is there to provide you with some details
- kridsana
Cirrocumulus
So Dashboard is show currently Performance is being used, right?
