Yevgeny_Libov's avatar
Yevgeny_Libov
Nov 04, 2019
How to get traffic throughput per second for a POOL in iRule
Hello guys,
I'm looking for a way to sample traffic going through two pools, aggregate it and check if the result is lower than a certain numeric number in Byte/Kbyte/Mbyte.
Basically, I'm looking for a syntax representation of the first line at the following syntax:
"If traffic (pool POOL1 + pool POOL2) < 900MB"
if { [class match [ip::client_addr] equals YOUTUBE] }
pool POOL1
Thanks,
Yevgeny
