Edouard_Zorrill's avatar
Edouard_Zorrill
Dec 12, 2017
How to failover two vCMP Guests in Cluster
Node1 says: Cluster Enabled Slot2: Active In Sync
Node2 says: Cluster Enabled Slot2: Standby In Sync
Question is, how do I make Node2 be the active one ?. It is different now as they are not appliances.
  • Login to Node1 and enter the below command.
    Tmsh run /sys failover standby
    Node2 will go to active status.
    Verify cluster status using below command
    tmsh show /sys cluster
