f5_rocks's avatar
f5_rocks
Jun 01, 2016
How to expand irule using switch or logical or in selection process?
Developers want to add more "lanes" for multiple branches, so I want to add 3 more versions of "starts_with" and make the "if nots" more generic so they can apply to all the "starts_with" versions. I've never tried using switch or a logical or in the selection process before. Do either or both attempts look correct?
abcd_redirect-http (original)
when HTTP_RESPONSE {event HTTP_REQUEST enable}
when CLIENT_ACCEPTED {event HTTP_REQUEST enable}
  set MY_HOST [string tolower [HTTP::host]]
  set MY_URI [string tolower [HTTP::uri]]
  if {$MY_URI starts_with "/abcd/"} {
   if {not ($MY_URI starts_with "/abcd/web/abcdpayment.web/") and not ($MY_URI starts_with "/abcd/web/abcdpaymentprocessing.web/")} {
    if {$MY_HOST equals "m3.corpname.com"} {
    HTTP::redirect http://a1.m3.corpname.com$MY_URI
    } elseif {$MY_HOST equals "intra.m3.corpname.com"} {
    HTTP::redirect http://intra.a1.m3.corpname.com$MY_URI
    } elseif {$MY_HOST equals "intra.m3-dc1.corpname.com"} {
    HTTP::redirect http://intra.a1.m3-dc1.corpname.com$MY_URI
    } elseif {$MY_HOST equals "intra.m3-dc2.corpname.com"} {
    HTTP::redirect http://intra.a1.m3-dc2.corpname.com$MY_URI
    } elseif {$MY_HOST equals "intra.m3-dc3.corpname.com"} {
    HTTP::redirect http://intra.a1.m3-dc3.corpname.com$MY_URI
  event HTTP_REQUEST disable
  TCP::close
abcd_redirect-http (trying switch -glob)
  switch -glob $MY_URI {
    "/abcd/"-
    "/abcd_lane2"-
    "/abcd_hotfix" {
    if {not ($MY_URI contains "/web/abcdpayment.web/") and not ($MY_URI contains "/web/abcdpaymentprocessing.web/")} {
  TCP::close
abcd_redirect-http (trying logical or ||)
  if {$MY_URI starts_with "/abcd/" || $MY_URI starts_with "/abcd_lane2/" || $MY_URI starts_with "/abcd_hotfix/" } {
  TCP::close
    1. Usually, when you add the iRule to the F5 LTM, it will throw one or more errors if there are syntax issues. Have you tried adding it to the LTM & do you see any errors ?
    2. See this for switch: https://devcentral.f5.com/articles/irules-101-04-switch
    3. I find the explicit event enabling commands "HTTP_REQUEST enable" redundant. I may be mistaken but I am not sure why you have to enable the event.
  • Hi,
    you can try this irule:
            "*/web/abcdpayment.web/*" -
            "*/web/abcdpaymentprocessing.web/*" {TCP::close}
            "/abcd/*" -
            "/abcd_lane2/*" -
            "/abcd_hotfix/*" {
                switch $MY_HOST {
                    "m3.corpname.com" {HTTP::redirect http://a1.m3.corpname.com$MY_URI}
                    "intra.m3.corpname.com" {HTTP::redirect http://intra.a1.m3.corpname.com$MY_URI}
                    "intra.m3-dc1.corpname.com" {HTTP::redirect http://intra.a1.m3-dc1.corpname.com$MY_URI}
                    "intra.m3-dc2.corpname.com" {HTTP::redirect http://intra.a1.m3-dc2.corpname.com$MY_URI}
                    "intra.m3-dc3.corpname.com" {HTTP::redirect http://intra.a1.m3-dc3.corpname.com$MY_URI}
            TCP::close
  • The proposed solution did not work, so I started over with my rule and incorporated the easy switch for the hostnames.
      if {$MY_URI starts_with "/abcd"} {
       if {not ($MY_URI contains "/abcdpayment.web/") and not ($MY_URI contains "/abcdpaymentprocessing.web/")} {
        switch $MY_HOST {
                    "intra.m3-dc2msp.corpname.com" {HTTP::redirect http://intra.a1.m3-dc2.corpname.com$MY_URI}
      TCP::close
