ask_me_anytime_'s avatar
ask_me_anytime_
Nov 06, 2008
how to disable management interface.
hi,
does anybody know to disable the management interface ?
"b interface mgmt disable " disables the interface temporarily but it doesn't persist across reboots...
I saw somewhere it was possible in SCCP, but I don't know the right commands to use there to disable the mgmt interface.
your help is highly appreciated.
  • hoolio's avatar
    hoolio
    If you disable the mgmt interface and then save the change using b base save, it should persist through reboots.
    The SCCP trick you referred to could be:
    1. ssh to sccp
    ssh sccp
    2. back up rc.network file
    cp -p /etc/rc.network /etc/rc.network.orig
    3. back up nvfiles.manifest file
    cp -p /etc/nvfiles.manifest /etc/nvfiles.manifest.orig
    4. Add rc.network to nvfiles.manifest
    echo "/etc/rc.network" >> /etc/nvfiles.manifest
    5. Disable eth0
    echo "ifconfig eth0 down" >> /etc/rc.network
    6. Initialize the change
    /etc/rc.network
    Making this change on the SCCP won't change the b interface mgmt output to show disabled--though using b interface mgmt disable will.
    Aaron
  • what about adding "b interface mgmt disable" in /etc/rc.local, eg.
    cat "b interface mgmt disable" >> /etc/rc.local
  • zafer's avatar
    zafer
    if you use rc.local then restart network services mgmt interface will goes up but if you set in to rc.networks it will see down command
    zafer
  • Does disabling the management interface kill lights out access to the sccp?
  • hi all,
    To disable the management port so that it persists arcoss reboots,
    you just need to execute command
    b base save
    after executing
    I tried that and it worked fine.
    so correct command order :
    b interface mgmt
    b base save
    I have tried to modify /etc/rc.network in sccp, but it doesn't work properly.
    I don't know why but mgmt port will be re-enabled after reboot.
    Thank you,
