sandip_kakade's avatar
sandip_kakade
Oct 28, 2021
How to disable and enable specific weak/good ciphers In SSL profiles. How to achieve this .
Please enable the below mentioned two strong ciphers and TLSv1.3 in state filing application
TLSv1.2 cipher TLS_RSA_WITH_AES_128_GCM_SHA256
TLSv1.2 cipher TLS_RSA_WITH_AES_256_GCM_SHA384
Also, remove the below weak ciphers
TLSv1.2 cipher TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA
TLSv1.2 cipher TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256
TLSv1.2 cipher TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA
TLSv1.2 cipher TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384
TLSv1.2 cipher TLS_RSA_WITH_AES_128_CBC_SHA
TLSv1.2 cipher TLS_RSA_WITH_AES_128_CBC_SHA256
TLSv1.2 cipher TLS_RSA_WITH_AES_256_CBC_SHA
TLSv1.2 cipher TLS_RSA_WITH_AES_256_CBC_SHA256
TLSv1.2 cipher TLS_RSA_WITH_CAMELLIA_128_CBC_SHA
TLSv1.2 cipher TLS_RSA_WITH_CAMELLIA_256_CBC_SHA
  • Hi sandip kakade,
    In client ssl profile:
    TLSv1_3:AES128-GCM-SHA256:AES256-GCM-SHA384
    With this cipher suite, the following ciphers will be usable.
    TLS13-AES128-GCM-SHA256/TLS1.3
    TLS13-AES256-GCM-SHA384/TLS1.3
    TLS13-CHACHA20-POLY1305-SHA256/TLS1.3
    AES128-GCM-SHA256/TLS1.2
    AES256-GCM-SHA384/TLS1.2
    IANA name:
    OpenSSL name:
    AES128-GCM-SHA256
    IANA name:
    OpenSSL name:
    AES256-GCM-SHA384
