Aneesh_138725
Jul 21, 2015How to create pool with range of port number eg: 33001-33100
I have requirement to create VIP range 33001-33100 which redirect to back-end server range 33001-33100.
I found below irule which can map with VIP port restriction. But not sure how to create pools.
when CLIENT_ACCEPTED { if {([TCP::local_port] >= 33001 ) && ([TCP::local_port] <= 33100) { pool Pool_name ===> } else reject }
- VernonWells
Employee
Create the pool members with the port set to 0, in the same way that you create the Virtual Server with the port set to 0.
