How to create pool and related jars?
Where we will get jars and supported files for creating a pool using programming lang.
- hoolio
Hi Patan,
I'd start here for info on iControl. If you have questions, please clarify which LTM version and which programming language you're using.
https://devcentral.f5.com/icontrol/getting-started
Thanks, Aaron
@Patan, you can get the iControl Library for Java binary .jar distribution here:
https://devcentral.f5.com/downloads/icontrol-assembly-java-binary
Once you have the libraries, check out the Java page in the iControl wiki:
https://devcentral.f5.com/wiki/iControl.Java.ashx
Hope this helps...
-Joe
