Aaron_McMahon_2
20 years agoHow to create a default node monitor?
I've been scouring the iControl documentation and can't find it... How do I create a default node monitor using iControl?
See graphic for how it appears in the GUI:
http://www.f5.com/images/sc/oracle_11i_v9_icmp.gif
- Monitors are defined as templates. Then you assign a template to an object to make a monitor instance.
In the SDK, take a look at the LocalLB::Monitor::create_template() method to create the template you want.
Then to assign a monitor template to a Node Address (which I assume you are referring to and not a Pool Member), look at the LocalLB::Node::set_monitor_association() method to create the assocation between the given Node Address and the monitor template that you previously created.
-Joe - Aaron_McMahon_2
Thanks, bro. You rock! - Anytime!
-Joe
