Thomas_Keller's avatar
Thomas_Keller
Jun 19, 2019
How to configure LTM to send a specfic client certifacte to backend sever if client certificate auth is required by backend?
Hi all,
i have to respond to a client certificat request from backend server with a fixed client certificate. It's not possible to configure the client to respond to a client certificate request. So i think ssl proxy or c3d is not a option.
Any suggestions ?
Thanks,
Thomas
  • Hi,
    You can add the client certificate for authentication to your server ssl profile. (it is the certificate and key in the server ssl profile).
    Cheers,
    Kees
