siyadh_121603
Jan 19, 2016How to configure F5 in hybrid mode..?
Hello,
we already deployed F5 LTM in NAT mode. As per new requirement we need to make some applications in hybrid/route mode. So we can choose either SNAT or Route mode depends on the application requirement.
- cjunior
Nacreous
Hi, If I understood you, depending on the application type, you could create an iRule or LTM policy rules to set up the SNAT to automap or pool (one-arm network) otherwise keep SNAT to none when in a routed mode (two-arm network). e.g. http application where you consider forwarding and balance by http hostname. Is that what you need? It's clear for you? Respectfully,
