Jaime_39945's avatar
Jaime_39945
Mar 29, 2012
How to configure another application hosting on same webservers?
I'm not an expert in this F5.
Application-A is on hosting on two physical web servers globally and using https port 443.
User will access url - https://appl-a.nnn.nn
In F5 LB, I created a Wide-IP and VS for application-A with port 443 (GTM and LTM).
Sometime later, a new application (Application-B) also wants to ride on the same physical servers and use F5 LB. This application-B is using https and port 8888.
i.e. https://appl-b.nnn.nn:8888
In my F5 LB GTM and LTM, how do I create for this new application?
For VS, should I use another new set of Virtual IP addresses or I can use the same VIPs created for application-A?
