How to config 2 Built-in Monitor in pool and use script on top of it?
From this picture scenario
How Can I make Availability of this pool member Online ?
(Assume https monitor is for web-tier and MySQL is for app-tier)
I want if https monitor available >> Availability of this member is Online even though MySQL is down.
And If https monitor down >> Availability of this member is Offline even though MySQL is Up.
Do I need to add additional script monitor to this member? or there is no way to do.
Thank you very much
PS. I assign two monitor for monitoring purpose only but for functional we can just monitor web-tier.
- kridsana
Cirrocumulus
Set Availability requirement to "at lest 1" is not good because
If https monitor down >> Availability of this member is still Online if MySQL is Up.
Client will fail in connectivity.
- kridsana
Cirrocumulus
we found the solution on test server about add another one monitor for web-tier and set Availability requirement to "at lest 2"
This time it will be monitor 1 >> check tcp port of web-service
monitor 2 >> check contenct of web-service
monitor 3 >> check tcp port of app-server
If we set "at least 2" , we can make sure that Availability of pool is Online when Web-service is up. and offline when web-service is down.
App-server is cluster so we ignore it even though it's down.
Is this practical solution? Please recommend us Thank you very much
- StephanManthey
Nacreous
Hi teepan123,
in case you want to use the same server for different services you can place it in different pools (even if the same service port is used).
You assign pool/service specific monitors and this way you will get a valid pool member availability state.
Thanks, Stephan - kridsana
Cirrocumulus
Thank you Stephan
I do as your advice to create a new pool for monitoring app only, and assign monitor separately.
Everything is fine, client can access normally and admin can see If service still working?
Cheers!
