Ruchit_Patel_31's avatar
Ruchit_Patel_31
Apr 09, 2018
How to capture Tcpdump
Dear All,
Kindly advise if there is a way to capture TCPDUMP on the F5 lab appliance provided by the F5 university.
I have done a capture but I know not how to transfer it to a PC and then probably check on cloudshark to analyse the dump.
I tried to download wine to support the WinSCP but it fails - seems like there is a restriction.
Can you advise any solution for this?
Regards, Ruchit Patel
  • You can use filezila with SCP to login bigip with administrator roles. So you can download it
  • Hello,
    Can you please confirm that you use root account (you can't with admin).
    Or your have the access with your specific account (Terminal access --> Advanced shell). In order to check go to System, Users then your account.
    Regards
