Puli's avatar
Puli
Mar 20, 2008
How to capture return messages in perl
Am trying to capture return messages in a perl variable so i can make decisions based on that.
Specificatlly am want capture return message from
$soapResponse = $PoolMember->get_session_enabled_state
SOAP::Data->name(pool_names => [@pool_list])
Can anyone help.
Ven
  • Do a site search on "PoolMember->get_session_enabled_state" and you'll see a bunch of perl samples using that method. Here's one from the CodeShare:
    http://devcentral.f5.com/wiki/default.aspx/iControl/TogglePoolMember.html
    Click here
    -Joe
  • Puli's avatar
    Puli
    sorry, more information.
    what am trying to do is capture the error message when username password is wrong.
    When i execute with wrong username/password. The code exits with below message
    401 F5 Authorization Required at checkLogin.pl line 414
    anyway i can capture this meessage into a variable so i can create a if then else to display user friendly message.
  • An example of that is in that sample on code share as well. Look at the checkResponse() subroutine. You can see if the fault member of the $soapResponse is set, and if so, get the value form the $soapResponse->faultcode and $soapResponse->faultstring.
    -Joe
  • Ok, I think I get what you are getting at. If you want to trap HTTP level error messages, you'll need to put an eval around your call and then interrogate the $soap->transport class's members (code, message, & status)
    eval {
    if ( $PoolMember->transport->status != 200 ) {
      print "Code   : ", $PoolMember->transport->code, "\n";
      print "Message: ", $PoolMember->transport->message, "\n";
      print "Status : ", $PoolMember->transport->status, "\n";
      exit;
    else
    Hopefully this get's you going.
    -Joe
