r23_78178
Mar 20, 2012How to Brick an F5
Hi ,
I have a question regarding formatting.
I remember reading a solution a while back that mentioned the possibility of bricking an F5 if a certain option was used during formatting.
I think it had to do with the image2disk command and trying to use the -no format option when upgrading to 10.X but I am not sure.
It was an F5 SOL but I can' find it anymore , and all I remember (hopefully correctly) is the mentioning of being able to "brick the device".
Does anyone have an idea what I am referring to ?
- hoolio
I don't remember anything about bricking a BIG-IP. Was this the SOL you were thinking of?
sol12561: Change in Behavior: The image2disk utility --instslot and --format options are now mutually exclusive
https://support.f5.com/kb/en-us/solutions/public/12000/500/sol12561.html
Aaron - r23_78178
Posted By hoolio on 03/20/2012 03:53 PM
Aaron
Hi Aaron,
Thanks.
That may be it, but I think the installation not only failed in the error but it also rendered the box unusable and needed a clean install.
