winifred_corbet's avatar
winifred_corbet
Aug 10, 2010
How to block Googlebot/Nutch-1.0 Bot
We have this Bot that is killing us:
Googlebot/Nutch-1.0 (Prototype; http://en.wikipedia.org/wiki/Web_crawler; donotreply at prototype dot com)
We would like to block it completely. I see there are irules to redirect Bots, but is there a simple one that can block this all together?
  • hoolio's avatar
    hoolio
    Hi Winifred,
    Sure, you can use a simple iRule to send a TCP reset if the user agent header contains that string:
        Check the UA header value, set to lower case
       switch -glob [string tolower [HTTP::header User-Agent]] {
          "*googlebot/nutch*" {
              Bad UA, send a TCP reset
             reject
    If you know the IP address(es) they typically make a request from you could do this more efficiently by adding the IPs to an address datagroup and then using the matchclass (v9) or class (v10) commands in CLIENT_ACCEPTED. This would avoid checking every HTTP request for the User-Agent header value.
    http://devcentral.f5.com/wiki/default.aspx/iRules/class
    http://devcentral.f5.com/wiki/default.aspx/iRules/matchclass
    Aaron
