Tham_T__330907's avatar
Tham_T__330907
Apr 11, 2018
How to automatically VPN when turn on machine?
Are there anyway to use SSL VPN network connect automatic when turn on the device (Windows OS)?
I things Edge Client can only save the password, but If that machine is not like end user device, any idea to do it.
Thanks so much.
  • Hello!
    I don´t think it is possible to auto-connect automatically when you turn on the device. You will have to login to the device first.
    //Cheers, Mike
