How to append to a match_class
I have this code:
if { ([class match $req_uri starts_with PROD_uri_to_redirecttossl]) } { HTTP::redirect "https://[HTTP::host][HTTP::uri]" }
but want something like this:
if { ([class match $req_uri starts_with PROD_uri_to_redirecttossl]) or ([class match $req_uri starts_with PROD_uri_to_redirecttossl]+"/*") } { HTTP::redirect "https://[HTTP::host][HTTP::uri]" }
Is that possible in an Irule, so I have datagroup: /about /help
I want the if to keep off of /about or /about/* but do not want to add /about/* to the dategroup.
Any suggestions?
thanks!
- AlexDeMarco
I think I answered my own question.. looks like +"/*" works.
- AlexDeMarco
okay well that did not work I get a connection reset in the browser..
So the question remains can I append to data returned via a class match?
if { ([class match $req_uri starts_with PROD_uri_to_redirecttossl] or [class match $req_uri starts_with PROD_uri_to_redirecttossl]+"/*") } { HTTP::redirect "https://[HTTP::host][HTTP::uri]" }
This does not work,.. any ideas?
- Kevin_Stewart
Employee
You can sort of think of a class like a list or array, in which trying to add a string to the end of the search criteria isn't going to add a value to each list element but rather to the reference to the list itself. Like searching a list, you'd necessarily have to iterate through each of its elements and add the string value before evaluation. Fortunately I don't thing you need to do that. You've specified that you want to send a redirect if the URI starts with "/about", which would encompass "/about", "/about/*", and "/about/anything-else-after-this-lowest-common-denominator-uri". In other words, the second URI evaluation would be unnecessary.
- AlexDeMarco
Kevin, thanks.. wouldn't it also hit on /aboutme or /aboutyou which is not what I want.
I need to redirect /about or /about/*
not exactly sure how to do this although it seems simple enough.
- Kevin_Stewart
Employee
Okay, this may seem a little odd, but I've gotten to work as follows:
Data group:
/about/ /help/iRule:
when HTTP_REQUEST { if { [string first "/" [HTTP::uri] 1] eq -1 } { URI doesn't have a second "/" so just return URI set mod_uri [HTTP::uri] } else { return the first level URI minus trailing "/" set mod_uri [string range [HTTP::uri] 0 [string first "/" [HTTP::uri] 1]] } if { ( [class match "${mod_uri}/" equals my-dg] ) or ( [class match $mod_uri starts_with my-dg] ) } { do something here log local0. "match" } }Essentially, I take the requested URI (ex. "/about/me"), strip it down to its first level path minus the trailing slash ("/about"), then compare it two times against the data group:
- Does the data group entry "/about/" equal the modified URI + trailing slash?
- Does the data group entry "/about/" start with the modified URI?
It will match "/about", "/about/", and "/about/me", but not "/aboutme".
- AlexDeMarco
ahh ok I follow you, so the dategroup would just have /about/ right?
- Kevin_Stewart
Employee
Correct.
