How to analysis qkview
Hello,
Could you please explain How to analysis qkview ?
- Kevin_Stewart
Employee
The very best way, in my opinion, is with iHealth:
https://ihealth.f5.com/qkview-analyzer/
In lieu of that, a qkview is essentially a tarball of the relevant portions of the filesystem (config directory, logs, etc.), so you can break it open and analyze it yourself (albeit manually).
- sinu_121261
Could you please explain How to analysis qkview ? for device reboot issue, tmm restarting issue.
- Kevin_Stewart
Employee
Go to https://ihealth.f5.com/qkview-analyzer/, log in with your support account, and then upload the qkview. iHealth will expand and analyze the qkview for you and generate a report of high/medium/low issues.
If that is not an option, open a support case.
- nitass
Employee
looking for log prior to the time tmm restarted. as Kevin mentioned, you may open a support case to get assistance from support team. qkview/ihealth, log tarball (if log is truncated in qkview), core and its md5 checksum (if had) are required.
sol2633: Instructions for submitting a support case to F5
http://support.f5.com/kb/en-us/solutions/public/2000/600/sol2633.htmlsol10062: Working with BIG-IP core files
http://support.f5.com/kb/en-us/solutions/public/10000/000/sol10062.html
