Network_km's avatar
Network_km
Mar 08, 2023
how to add multiple monitor with min availability function for existing pool in f5
I have a pool containing few members with the custom monitor attached. My requirement is to add additional members and monitor to the existing pool with the min availabity function  (so that min one monitor should respond to the server and marked up)
Please share the CLI command to modify the setup
  • I you have multiple monitors, there is an 'availability requirement 'setting that lets you choose how many monitors would require a member to be UP. here is an example:
    ltm pool Tiny_pool {
    members {
    172.16.100.11:http {
    address 172.16.100.11
    priority-group 2
    session monitor-enabled
    state up
    172.16.100.12:http {
    address 172.16.100.12
    priority-group 2
    state down
    min-active-members 2
    monitor min 1 of { gateway_icmp http }
    service-down-action reset
    In the example above, I've set up 2 monitors (gateway_icmp and http) and a minimum of 1 can make the pool member as UP.
    • Network_km's avatar
      Network_km
      Hello Mihaic,
      Thank you for quick response
      I'm looking for the cli command that serves below condition in single "modify pool" command
      add additional members to existing pool
      add additional monitor to the existing pool (old monitor should not be removed) with the min available condition between monitors
  • here is an example based on where I am adding tcp monitor to the pool monitor from the example above:
     modify ltm pool Tiny_pool monitor min 1 of { gateway_icmp http tcp }
