How many monitor we can assign to single pool
How many monitor we can assign to single pool to check the availability of the pool. Do you have any written notes for that. Please share with me and if we need to make script how we can write that script
- What_Lies_Bene1
Yes you can assign multiple monitors to a Pool (or Pool Member). If you do, you can also configure an Availability Requirement and specify the number of monitors required to consider the object as UP.
No script required unless I misunderstand your question on that.
- keshav_163381
Yes i have configured same thing in one of my setup. its like and request check all the monitor (you can also assign no of monitor should be up ). In my case we have to configure with or if first assign monitor is up then pool is also and no need to check rest configure monitor to the pool with OR request.I think we have configure with external monitor with own script
- What_Lies_Bene1
Yes, if you would like to only check further if the first monitor fails you'll need an external monitor.
- hoolio
Hi Keshav,
If you do opt for an external monitor, here's a template you can start with:
https://devcentral.f5.com/wiki/AdvDesignConfig.TemplateForExternalLtmMonitors.ashx
Aaron
- keshav_163381
Thanks for your reply :)
