How do I issue and HTTP::retry to a different location based on an ICAP result (ADAPT::enable 1)?
It seems that HTTP retry is only available in the HTTP_RESPONSE and HTTP_RESPONSE_DATA events. But if I issue an ADAPT for a response adapter in the HTTP_RESPONSE event then want to use that response to determine whether to retry, there doesn't seem to be any way to do so.
- nitass
Employee
would it be possible to use HTTP::respond instead?
i have limited knowledge about icap server configuration. anyway, this is my testing. not sure if it is useful.
config root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm virtual bar ltm virtual bar { destination 172.28.24.10:80 ip-protocol tcp mask 255.255.255.255 pool foo profiles { http { } myresp_adapt { context serverside } tcp { } } rules { qux } source 0.0.0.0/0 source-address-translation { type automap } vs-index 7 } root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm profile response-adapt myresp_adapt ltm profile response-adapt myresp_adapt { app-service none internal-virtual adapt } root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm rule qux ltm rule qux { when HTTP_REQUEST { log local0. "" set host [HTTP::host] set uri [HTTP::uri] } when HTTP_RESPONSE { log local0. "" } when ADAPT_RESPONSE_RESULT { log local0. "ADAPT::result = [ADAPT::result]" if { [ADAPT::result] equals "bypass" } { set redirect 1 } else { set redirect 0 } } when HTTP_RESPONSE_RELEASE { log local0. "" if { $redirect } { HTTP::respond 302 Location "http://${host}${uri}" noserver } } } root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm virtual adapt ltm virtual adapt { destination any:0 internal ip-protocol tcp mask any pool c-icap profiles { myicap { } tcp { } } rules { myrule } source 0.0.0.0/0 translate-address disabled translate-port disabled vlans-enabled vs-index 9 } root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm rule myrule ltm rule myrule { when ICAP_RESPONSE { log local0. "ICAP::status = [ICAP::status]" if { [ICAP::status] == 200 } { IVS_ENTRY::result noop } } } test [root@centos1 ~] curl -I http://172.28.24.10 HTTP/1.0 302 Found Location: http://172.28.24.10/ Server: BigIP Connection: Keep-Alive Content-Length: 0 /var/log/ltm [root@ve11a:Active:In Sync] config tail -f /var/log/ltm Sep 6 02:08:59 ve11a info tmm1[15094]: Rule /Common/qux HTTP_REQUEST: Sep 6 02:09:02 ve11a info tmm1[15094]: Rule /Common/qux HTTP_RESPONSE: Sep 6 02:09:02 ve11a info tmm1[15094]: Rule /Common/myrule ICAP_RESPONSE: ICAP::status = 200 Sep 6 02:09:02 ve11a info tmm1[15094]: Rule /Common/qux ADAPT_RESPONSE_RESULT: ADAPT::result = bypass Sep 6 02:09:02 ve11a info tmm1[15094]: Rule /Common/qux HTTP_RESPONSE_RELEASE: - rahulpr_134840
HI Nitass
which OS are are running in ,For Me it seems 11.5 does not support redirect in "when HTTP_RESPONSE_RELEASE" event
