JasonTheF5Guy's avatar
JasonTheF5Guy
Jan 31, 2024
How do I figure out if F5 has an attack signature or threat campaign for a given vulnerability?
Given the recent Ivanti vulnerabilities I'm wondering if F5 has released any pertinent attack signatures and/or threat campaigns to help me defend against these vulnerabilities. However I'm not finding a straightforward answer.
I'm searching for CVE-2023-46805 and CVE-2024-21887 across the F5 sites and nothing helpful is coming up. Is there a search tool that I can use to help me discover quickly if a given vulnerability is remediated by ASM?
Thanks,
Jason
  • Hi JasonTheF5Guy
    I see the mentioned CVEs are related to ivanti :
    So if you have any solution related to ivanti ( x pulse secure ) you can check and apply the needed workarounds.
    F5 announces each quarter all found CVEs and sometimes doesn't wait for each quarter in case of urgent or critical CVEs, thus I don't see any relatively to F5.
    • JasonTheF5Guy's avatar
      JasonTheF5Guy
      Yes, these are Ivanti related CVE's.
      It's possible to protect an Ivanti solution by putting it behind an LTM/ASM and configuring a security policy within ASM. If somebody had done that then I'm wondering if F5 has a web site where I can quickly search for a given CVE (or some other vulnerability) and see if there is either a pre-packaged attack signature or threat campaign formulated to protect against that given vulnerability.
