Salvatore_Berti's avatar
Salvatore_Berti
18 years ago
how disable compression for a specific javascript?
Hi guys,
I've got a page with 3 js files
and I've been trying to disable compression for one of them using the irule below:
rule salvo_selective_compress_disable {
if { ([HTTP::host] eq "1.1.1.1") and
([HTTP::uri] eq "/salvo/1.js") } {
log local0. "compression_rule"
COMPRESS::disable }
I can see the entry in the log but the js is still compressed, however if I use an http profile with selective compression and use the irule below I can see that only the file specified in the irule is compressed and no the other 2 (that is actually what I expect)
rule salvo_selective_compress_enable {
COMPRESS::enable }
I don't get where the difference is, can anyone help me to figure out what is going on or give me an hint?
Thanks in advance.
Waol
  • The COMPRESS::disable in the first rule won't work without the selective compression profile, which is why you're seeing all of the files compressed. It's listed as only working with that profile selected on the wiki
    http://devcentral.f5.com/wiki/default.aspx/iRules/COMPRESS__disable.html
    So I would think that the best bet would be to try and use selective compression and enabling compression for everything except the particular file you don't want compressed.
    I would maybe try something like this
            if { ([HTTP::host] eq "1.1.1.1") and ([HTTP::uri] eq "/salvo/1.js") } {
                log local0. "compression_rule_disable"
                COMPRESS::disable
            else {
                COMPRESS::enable
