Allwyn_Mascaren's avatar
Jan 12, 2019
How Destination persistence works?
Basically I don’t get which dst is would be used.
The one on the vs or the ip of the pool members after auto map?
And how will a client ever get the same pool dst ip for the persistence to work if a load balancing algorithm would be executed before choosing the pool members?
  • It is referring to the destination address for the client, which is the VIP address.
    HERE is a pretty good post on here concerning this same subject.
    And HERE is some more info on persistence profiles from F5.
    Hope that helps! If it does please up-vote and select this answer, it'd be greatly appreciated!
    -Dylan
